Old 27-07-2009, 07:10 PM   #1 (permalink)
Default two problem 1st is wifi problem and second is outlook 2007
hello guys
i have installed mtnl wifi hg 520 for wifi connectivity
i am having two laptop one desktop and two phones having wifi connectivity
both laptop is of lenavo having vista and xp installed
configuration
laptop 1
win xp
celeron
512 mb ram
laptop 2
vista
c2d 2.0
3gb ram
i have setup as like that hg 520 is connected with desktop with the wire and laptops and phones are getting connected with wifi....i have secured wifi with wep 128 bits n now problem is that when i am enabling this security then laptop having window xp is not conecting and when i disable this security laptop having vista is not getting connected
in my setting i have disabled mac filter,dhcp enable,ssid on security wep 128 bit
what to do as i wana keep this security and wana laptop having xp to be able to connect it with also....it can be able to search the wifi n asking for the key but key is not working in the laptop having xp whearas laptop having vista n both the phones are getting connected by the same key...error message is that this connection has limited connectivity......what to do
plz explain in step wise as i am noob
2nd problem
i dont know much about outlook but my father use outlook 2007 n now he wana transfer his contact from out look to gmail....now as i googled and tried the process of csv file formation n succeeded in transferring the contact but its only three contact so i checked the contacts in my father outlook account and it shows that it really consist of only 3 contacts but while sending the mail when you type the 1st letter you will see all the contact there...now plz tell me how to get these contacts in contacts folder or transfer them in csv file
ashishstillthere is offline
Old 27-07-2009, 07:41 PM   #2 (permalink)
paroh's Avatar
Default Re: two problem 1st is wifi problem and second is outlook 2007
I think u are using windows xp without service pack 3? if yes install windows xp sp3 and try again and also enable dhcp. If u are using mtnl HG50 (TREANDCHIP) i can post the screenshot of it.
And please clear how u are connecting to desktop PC and your Two laptop (Are u using only one phone line?)
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
Old 28-07-2009, 01:37 AM   #3 (permalink)
dhcp is already enabled
ya i am using trendchip
i am using hg 520 provided by mtnl so it has 4 lan port so i had connnected one port with my desktop(as its not a wifi one) by lan wire and laptop having vista and xp n phones are getting connected by wifi
ya i am using only one phone line
about service pack i will tell you later as that lappy(having xp) is of my dad
Old 28-07-2009, 01:51 AM   #4 (permalink)
Old 03-08-2009, 11:31 AM   #5 (permalink)
Regarding the 2nd problem,the names that you get when you type something in the to or cc or bcc fields are the mail ids to which you have sent mail before and not the contacts in the addressbook
vineeth12345 is offline
Old 03-08-2009, 05:33 PM   #6 (permalink)
thn how to send them on contact book
Old 05-08-2009, 10:49 AM   #7 (permalink)
AFAIK you cannot copy the address cache into contacts list.
Old 05-08-2009, 11:15 AM   #8 (permalink)
then plz help me to sort out this problem
This is a troll thread.
This is a troll thread. It has to be. buy wow goldcheapest wow gold wow gold fast deliveryeve iskwow cd key
what do u mean by this
Old 05-08-2009, 12:20 PM   #9 (permalink)
Just check this
http://www.nirsoft.net/utils/outlook...ocomplete.html
I have not tried this out.Use at your own risk.Hopefully this should solve this.
- by gohan89
