Old 26-07-2009, 08:10 PM   #1 (permalink)
Default What and how to do?
*I have got Internet Download Manager (version 5.15 Build 5) in which there is a Tap named Dial UP wherein there is an option as Connections options under which are as follows:
Connection
Username
Password
What is the purpose and function of these options?
*Whenever I open Firebox 3.5 Beta4, there is a comment as below: How to correct it?
firefox.exe - Entry Point Not Found
The procedure entry point _except_handler4_common could not be located in the dynamic link library msvcrt.dll.
OK
kumarn_2004 is offline
Old 26-07-2009, 08:43 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: What and how to do?
As per you first query, if you are not connected to the internet and you ant to resume a download, you can automatically resume the download by jut clicking Resume in the menu. The entries you entered in dial-up will be required then. It will the same thing(i.e. dialing) to connect to the internet.
Check this site for answer to your second query.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
- by gohan89
