Old 25-07-2009, 07:22 PM   #1 (permalink)
Flashbang's Avatar
Angry Help!!! Project1 Virus
My pc is infected with project1 virus .I saw it when i saw dep error during startup.I can't find any proper removal steps or software....
Anyone please give me some instructions how to remove it ??
(I use Windows Vista)
Flashbang is offline
Old 25-07-2009, 07:25 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Help!!! Project1 Virus
Update ur antivirus and scan ur pc........
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 25-07-2009, 07:27 PM   #3 (permalink)
Flashbang's Avatar
Use avast with automatic updates + Spyware doctor
Old 25-07-2009, 07:42 PM   #4 (permalink)
Simply a DIGITian
May b ur AV hav been disabled/corrupted/bypassed
Scan online(If u r on unlimited plan)
Othrwse install some good antivirus update it and scan.....
Old 25-07-2009, 07:44 PM   #5 (permalink)
Flashbang's Avatar
Currently running Spybot, Threatexpert Scanner and ad-aware
Old 25-07-2009, 08:05 PM   #6 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Install Avira Antivirus Free and do a system scan.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 28-07-2009, 07:58 PM   #7 (permalink)
Flashbang's Avatar
Everyone gives useless advice
Old 28-07-2009, 08:17 PM   #8 (permalink)
Call me D_J!
So from when a suggestion for a virus scan became useless?
And it's Avira...one of the best antivirus with 99.7 % detection rate of virus.
And you find it useless?
Ok no probs then....If you want to use some thing for removing...try this software. Though I recommend it when every other antimalwares fail.
Old 03-08-2009, 12:39 PM   #9 (permalink)
try combofix..run it in safe mode
:P If U lIkE mY SUggeStIon Plz ADd SOmeThing tO mY RePUtaIon :)
buntythecool is offline
- by gohan89
