Old 22-07-2009, 08:22 PM   #1 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Help With Excel 2007
Hi frndz........When I type 2/14 in any cell it gets automatically converted to 14-Feb. What shud I do to stop this???
No Auto-Formatting pop up is coming from which I may revert the change. I also tried to stop auto-formatting. But no results. Pls help. I need to submit ths excel document to coll 2moro. Plz help ASAP.
Thnx in advance
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 22-07-2009, 08:46 PM   #2 (permalink)
Default Re: Help With Excel 2007
Type it in like this:
`2/14
The ` is the leftmost of the number keys : ~/`
Whatever is entered in a cell with the apostrophe is front of it will automatically be treated as text.
pillainp is offline
Old 22-07-2009, 08:51 PM   #3 (permalink)
Simply a DIGITian
thnx........!!
I found another way......
Well b4 writing nythng 2 cell If I convert it to text.......it doesn't get changed....!!!
Old 22-07-2009, 08:54 PM   #4 (permalink)
That is the other way.
Good to see you got it solved.
pillainp is offline
Old 01-08-2009, 11:34 PM   #5 (permalink)
I have another problem.
I am not getting the small square at the bottom right hand corner of selected cell. As a result most of the guys in my family are not able to click on it and copy the contents or formula in the cells below. Plz help.
krdalmia is offline
Old 03-08-2009, 07:25 PM   #6 (permalink)
Look at the attached picture. That option should have be checked to enable drag fill. You can find it Excel Options (Orb>Excel Options) on the Advanced page.
pillainp is offline
- by gohan89
