@Pravas
- Check under Event Viewer > System for any errors related to this.
- Any errors in Device Manager ??
- Have u tried uninstalling the drive from Device Manager ??
Windows cannot read from the disk.the disk might be corrupt or using a format that is not comparible with windows."
First sign of a dying dvd lens.
- Hope you writing at lowest speeds ?
- Try, reducing "Read Speed" using Nero's "Control Drive's Speed". Worth a try.
