@lahratla
...resolution like 640x480 or 352x240 that are not widescreen format...
These are full screen resolution, AR : 1.333 (4:3 = 1.333). What you need is 1.777 (16:9 = 1.777).
- Have you removed the black borders from the dvd-video? If so, this is wrong resolution/aspect ratio.
- What you use to convert ?
- Have you tried diff display settings in your tv/dvd player. Do check properly before answering any of this.
