Old 06-07-2009, 09:24 PM   #1 (permalink)
sagnik_bose's Avatar
Exclamation DVD drive not showing contents
i have a system wid win xp wid sp2 .my dvd drive doesn't show up d contents under windows explorer but d contents ar visible under isobuster or other 3rd party softwares.pls helllllllp
sagnik_bose is offline
Old 06-07-2009, 09:33 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: DVD drive not showing contents
Uninstall the DVD drive.....restart and reinstall and check!
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 08-07-2009, 06:11 PM   #3 (permalink)
You can have number of problems..\
Firstly,It could be a virus or faulty OS
Secondly,Cables could be loose.
Try opening the cables and putting them back,that might solve the problem..
Or reinstall the Operating System.......
thetechfreak is online now
- by gohan89
