Old 04-07-2009, 02:51 PM   #1 (permalink)
ajayritik's Avatar
Default Getting an error message whenever the computer boots! What could be the problem?
I recently found that I get the following message whenever I start or reboot my PC.
Intel(R) Manageability Engine(ME) requires a DIMM in Channel 0.
ME is non-operational until this is complied with.
Press the Enter key to continue.
This started after yesterday when my PC Cabinet fell down from the table. Could the impact have caused the problem? The PC was behaving weird hence I replaced the RAM into another slot. Could this be the problem as well?
ajayritik is online now
Old 04-07-2009, 04:33 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Getting an error message whenever the computer boots! What could be the problem?
Most probably that seems to be a RAM problem. How many RAM slots u have? Insert it in another slot and then see. Or change that RAM with another for some time and then see if the problem exists or not.
Blogging at:
Technostarry
saqib_khan is offline
Old 04-07-2009, 04:54 PM   #3 (permalink)
ajayritik's Avatar
As mentioned initially when the Cabinet fell down. I started the PC to find the screen behaving weird. So I replaced the RAM by placing it in an another slot. Since I replaced it in another slot the error message started.
Old 04-07-2009, 05:25 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
IT seems that the motherboard damaged because of felling down. Anyways, let other's also comment on ur problem.
Blogging at:
Technostarry
Old 05-07-2009, 01:18 PM   #5 (permalink)
Termin@L's Avatar
TS the ram by using in another compatible mobo n also try diff ram in diff slots alternately on UR mobo.
Don't go to sleep angry!
Stay up and plot your REVENGE!
Termin@L is offline
- by gohan89
