Old 03-07-2009, 02:29 PM   #1 (permalink)
Default system freeze in bios
Hello,
Lately, my system has been freezing up after the "Memory runs at single channel" after the memory test screen..
after about 1-2 mins, it then boots up regularly..
What could the cause of this?
Thanks
PS: mobo = Giga G31 S2l proccy = e5200 Ram = 1Gb 800 Transcend
To be or not to be...
spy king is offline
Old 03-07-2009, 03:15 PM   #2 (permalink)
Default Re: system freeze in bios
Originally Posted by spy king View Post
Hello,
Thanks
Transcend
U just check in a bios. there is one tab to disable memory check.
This will help u.
sumeet.bheke is offline
Old 03-07-2009, 03:32 PM   #3 (permalink)
hello,
I am unable to access any of the advanced bios functions.. it just hangs..
spy king is offline
Old 03-07-2009, 04:04 PM   #4 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Check this site: https://www.evga.com/forums/printable.asp?m=100673602
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 03-07-2009, 08:20 PM   #5 (permalink)
thanks! I shall try clearing CMOS and checking if that helps
spy king is offline
Old 05-07-2009, 10:03 AM   #6 (permalink)
No luck.. cleared the CMOS, but still took 10 mins to enter the CMOS screen it self..
spy king is offline
Old 05-07-2009, 10:09 AM   #7 (permalink)
Your M/b have corrupt Bios. The only solution is to update it. If thats not possible then send to the the Mamufacturer Company for repair.
jeetu is offline
- by gohan89
