Old 02-07-2009, 08:15 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Smile Photo resizer software required (Batch converter)
Hi
I have many pics of size 2348 * ..... (approx 2 MB each) ...I resize them by using Irfanview one by one to size 1024*768 so that I can upload them easily on orkut,picasa etc
Now prob is that I want a software that can convert say 100 files in a go to my desired size ie 1024*768 ....ie I need a batch convertor
Can somebody suggest such a good photo resizing batch convertor
Thanks
Sumit
esumitkumar is offline
Old 02-07-2009, 08:39 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: Photo resizer software required (Batch converter)
How about Fotosizer and Free Photo Converter
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 02-07-2009, 08:51 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
I Use Photoscape
It's open source.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 02-07-2009, 08:59 PM   #4 (permalink)
Here Since 2003
Indyan's Avatar
Irfan View has a Batch Processor that can do the task (shortcut is B, you can also access it from File Menu).
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Old 02-07-2009, 11:01 PM   #5 (permalink)
Cool G5's Avatar
Post Re: Photo resizer software required (Batch converter)
Irfanview is good for you. Just press 'B' to open Batch convert/resize window, set the options as per your needs & press Start to begin the batch conversion/resizer.
Cool G5 is offline
Old 07-07-2009, 10:52 AM   #6 (permalink)
RPG FTW!!!
Techn0crat's Avatar
Open irfanview,press B.
Select Advanced.It will open new dialog box.select appropriate options and click ok.
Hope this image might help:
Techn0crat is offline
Old 07-07-2009, 01:48 PM   #7 (permalink)
Call me Sumit
Ya Photoscape does the work ....Thanx ...
- by gohan89
