Old 20-06-2009, 06:25 PM   #1 (permalink)
THE SIMPLE MAN
MR.MOUSTACHE's Avatar
Question xp installation using pen drive ??
my system has crashed and i want to reinstall the xp os using my pen drive is it possible ..... i have the xp file in .gbi format so can u guys help me...... i mean how to do it and what will be required and all ... thanks in advance
People laugh Because Am Different. And I Laugh Because They Are All The Same......
MR.MOUSTACHE is offline
Old 20-06-2009, 08:28 PM   #2 (permalink)
Default Re: xp installation using pen drive ??
XP cannot be installed through pen drive, since in XP the USB booting is blocked.
But not in Linux.
Mr.Digital is offline
Old 20-06-2009, 08:31 PM   #3 (permalink)
Freak Beta 1
Dark Core's Avatar
Use this tutorial dude - http://komku.blogspot.com/2008/11/in...lash-disk.html
Twitter : www.twitter.com/arunselvakumar :twisted:
Facebook : www.facebook.com/arunselvakumar :evil:
Dark Core is offline
Old 20-06-2009, 09:12 PM   #4 (permalink)
Wandering In Tecno Land
Ecko's Avatar
^^ Works
Tried it many times
Warning Ur Dual Boot may Get Corrupted
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 20-06-2009, 09:48 PM   #5 (permalink)
Here Since 2003
Indyan's Avatar
But not in Linux.
Not true.
The best and the easiest option it to use WinSetupfromUSB. All you need to do is to specify the xp installation folder and the location of pendrive. The software takes care of the rest. You dont need to go through the elaborate procedure mentioned by Black Core.
In fact you can install pretty much any OS from pen drive.
My Blog :: http://www.pallab.net
Twitter :: http://www.twitter.com/indyan
Indyan is offline
Old 21-06-2009, 07:30 PM   #6 (permalink)
THE SIMPLE MAN
actually my doubts is if the xp image file i have will work or not its a format call .gbi which i have never came across
Old 21-06-2009, 10:06 PM   #7 (permalink)
Freak Beta 1
Dark Core's Avatar
It's gburner Image File,
Visit www.gburner.com for details
Old 21-06-2009, 10:07 PM   #8 (permalink)
Freak Beta 1
Dark Core's Avatar
Old 21-06-2009, 10:09 PM   #9 (permalink)
Freak Beta 1
Dark Core's Avatar
Why d **** s my Post double every time I post ??
Old 22-06-2009, 09:26 PM   #10 (permalink)
THE SIMPLE MAN
ya i know but this time i want to do it through pen drive and keep it for permanent.
- by gohan89
