Old 18-06-2009, 10:57 AM   #1 (permalink)
napster007's Avatar
Default Problem installing XP....need help URGENT
hello,
i have been facing problems installing windows xp on my compaq c300 laptop. when i boot up with the CD it loads the necessary files and stuff and in the first option menu where it asks if i want to install or repair and stuff, when i select to install the XP, it says that the "No hard disks have been found connected to the laptop". this problem had occured before but at that time it got solved when i disabled the 'Sata native support' in the BIOS. but now it makes no diference wether i turn it on or off.
please help me with this problem, i need to get my laptop running ASAP.
regards.
napster007 is offline
Old 18-06-2009, 11:06 AM   #2 (permalink)
Default Re: Problem installing XP....need help URGENT
Coz the SATA drivers for your hard disk is missing. You must first install SATA drivers when the those Windows files loads. The very first option would be i think "Press F2 to install third party SATA drivers" or something! If you dont have the drivers use the option i did, on my PC, went to BIOS and there was an option saying use the HDD as IDE. I selected that and installed XP.
hell_storm2006 is offline
Old 18-06-2009, 11:25 AM   #3 (permalink)
paroh's Avatar
First enable sata support in ur bios and download the sata drivers
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32478.exe
U need to customize ur windows xp installation disk by using nlite and intergrate the sata drivers in ur xp installtion disk download nlite from here
http://www.nliteos.com/download.html
see how to use nlite to intergrate the drivers use this tutorial
http://www.winaddons.com/nlite-14-tutorial/
Note to use nlite u need Net Framework 2.0
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
- by gohan89
