Originally Posted by paroh
I think there is some problem with the file system or the os (But on the other hand it is very strange that ur os is working) . you should take the backup of ur data immediately and format the drive and reinstall the os and software.
i have installed Xp recently.i have ran chkdsk from repair option and it runs ok .but in normal mode it says file system is raw.if the os is running fine may there is some problem while accessing the drive by some software as well as xp.some programs like parttion expert doesn't detect the drive but other detects the drive and dvd writers.isn,t there any option without formatting as os is working fine.
one more thing all detect only logical drive but they don't show physical drive.i device manager there are following entries as:
AMD PCI IDE Controller
AMD SATA Controller (Native IDE Mode)
Primary IDE Channel
Primary IDE Channel
Secondary IDE Channel
Why there are double entries .
i have SATA HD and Two IDE DVD Drive.
1rst Primary IDE Channel -Master UDMA 6
2nd " -Master UDMA 4
Slave UDMA 2
Why it is showing three ide device.i have only two.
