Old 15-06-2009, 08:32 AM   #1 (permalink)
avtarkaint's Avatar
Question problem with gphone.exe
whenever i start my pcafter destop comes to the screen this gphone.exe error comes on screen & irritate me alot.
in the error message it say gphone.exe is not a valid windows file.
please give me solution.
system:
microsoft windows XP proffesional version 2002
service pack 2, intel(r) pentium(r) 4 cpu 2.66GHz
248 MB of RAM
using- AVAST antivirus professional updated regurarly
avtarkaint is offline
Old 15-06-2009, 10:00 AM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: problem with gphone.exe
Gphone.exe is a malware which gets into the Windows directory. To remove it you have to download Reg Run and run it.
http://www.greatis.com/appdata/d/Win...xe_Removal.htm
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 17-06-2009, 09:45 AM   #3 (permalink)
I too had the same problem some time earlier.
A simple Malware Scan Solved it.
Aspire is offline
- by gohan89
