Re: LAN driver problem
If that's an onBoard LAN Card, you need to get the driver from Motherboard Manufacturer's website or you can install it using the CD that came with your motherboard. If its external, use the CD that came with the card or from its website
AMD Athlon 64 X2 Dual Core 6000+ 3.0GHz - 320 GB SATA - LG & Lite-On DVD Burner - iBall Designer Series Cabinet - Creative SBS A300 - Samsung 19" WideScreen
Techie | Freelancer | Student
