Old 06-06-2009, 10:34 PM   #1 (permalink)
Default New Hard Disk Capacity & Partition Problems
Hello everybody: -
I bought a new Seagate Barracuda 320 GB HDD. & plug it alongwith my existing 160 GB HDD & Boot from the New Seagate HDD & Install OS = XP SP-3 on it.
1st Problem: Disk Management shows capacity of New HDD = 298.09 GB. Where 20 GB can be gone??
I Partition it as follows: -
C: (System Partition) = 100 GB
E: (Logical Drive) = 60 GB, 1st I create an extended partition then convert it to Logical Drive.
Unallocated Space = 138.09
2nd Problem: To partition the Unallocated Space, I right click on it. But in the New Partition Wizard, only Primary Partition option is active. Extended partition & Logical Drive options are NOT Active. Why they are inactive?
How other Extended partitions can be created?
jbohaj is offline
Old 07-06-2009, 12:25 AM   #2 (permalink)
Default Re: New Hard Disk Capacity & Partition Problems
Nothing wrong with the capacity. Manufacturers calculate 1000 bytes = 1 kilobyte instead of 1024 bytes = 1 kilobyte. So all HDD's actually have less space as compared to what is advertised (93.13% of the original to be exact).
drvarunmehta is offline
Old 07-06-2009, 07:55 AM   #3 (permalink)
Thanks. Capacity doubt is clear!.
But why Extended Partition Option is Inactive in Disk Management > New Partition Wizard??. How Logical Drives (D:, E:, F:, G: etc) can be crated using Disk Management??.
jbohaj is offline
Old 07-06-2009, 08:07 AM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
just put u r WINDOWS XP bootable disc and boot it, and create partition frm their
VarDOS is offline
- by gohan89
