| Forum |
#1 (permalink) |
I cant install windowsXP in my recently bought laptop Acer Extensa4630. But I can install vista or windows7beta without any problem On installing xp, while copying files, it stops abruptly saying that check harddisk configuration. But I need xp .Pls advise...thnx in advance... |
#2 (permalink) |
damnbadman666
Go to the BIOS settings --> Change the SATAMODE from AHCI to IDE , then u can install XP !!
AMD Phenom 2 940 @ 3.4Ghz [Hyper 212+] ![]() |
#4 (permalink) |
Now everything is ok.I could install windows xp.Thanks for the support. One more thing to ask can i remove unwanted services and language packs from the windows installation file/cd
#5 (permalink) |
Freak Beta 1
You can use nLite to remove unwanted services nd language packs ( Make an ISO image and burn it into disc ) then boot the disc to install the OS
Twitter : www.twitter.com/arunselvakumar Facebook : www.facebook.com/arunselvakumar |
#6 (permalink) |
Freak Beta 1
| Bookmarks |
| Thread Tools | |
| Display Modes | |
