Old 04-06-2009, 03:00 PM   #1 (permalink)
Exclamation UNINSTALL LINUX (PLZ HELP)
.. hi ..
A few days ago i had installed linux in my pc and now removed that from computer management >> disk management .
but when i restart my pc it sayd grub loading failure.
i tried to boot using xp n 98 bootable cd but it doesnt work
please tell me what to do now .
i dont have linux cd or floopy with me
prsntcool is offline
Old 04-06-2009, 03:03 PM   #2 (permalink)
Default Re: UNINSTALL LINUX (PLZ HELP)
plz .. email me at .. prsntcool@yahoo.co.in
Old 04-06-2009, 03:08 PM   #3 (permalink)
Linux User
ghost at rest's Avatar
Hi and Welcome !
Does machine boot up from Windows 98 Installation CD?
Download Windows 98 Bootable Floppy from bootdisk.com. Boot up machine from Floppy and execute this
A:\> fdisk /mbr
It will remove GRUB and Windows OS will boot up fine.
In case you don't have Floppy Driver, download SuperGRUB CD/USB from supergrubdisk.org, boot up from it and select Fix Windows Boot Loader option.
ghost at rest is offline
Old 04-06-2009, 03:11 PM   #4 (permalink)
Just Format Your HDD and reinstall Windows
Crazykiller is offline
Old 04-06-2009, 03:11 PM   #5 (permalink)
You wanna be a victim of Gay p*rn ?
Posting your Email Here is not safe at all.
Old 04-06-2009, 07:27 PM   #6 (permalink)
If u have ur XP cd, just boot frm it, select recovery console, frm there type 'fixmbr'
a55a55in is offline
Old 04-06-2009, 08:31 PM   #7 (permalink)
Linux User
Partition Formatting won't make any difference because GRUB doesn't reside in any Partition.
fixmbr command work only if machine boots up fine from Windows Installation CD but installation CD doesn't work in a few machines. It couldn't past Hardware detection screen. Its a GRUB/BIOS compatibility problem. It is one of the reason for discontinuing GRUB development by its developers. Team is working on GRUB2 now.
As I suggested earlier, if Windows Installation CD is not working, use Windows 98 Bootable Floppy or SuperGRUB CD/USB.
Old 04-06-2009, 09:40 PM   #8 (permalink)
errrrr ... u seems rite but . i am so dumb in this downloading stuffs ,.. can u please please please post the link to download the superscrub cd download link ..
i visited the site . bt its complicated to find where the link is
Old 04-06-2009, 09:44 PM   #9 (permalink)
I meant Complete Formatting of HDD
Won't that work?
Old 04-06-2009, 09:48 PM   #10 (permalink)
Boot with the Windows XP installation CD.
Go to the Recovery option and type fixmbr and press enter.
The Windows boot loader will get installed and you'll be able to use Windows again.
Or you can also do what ghost-at-rest said.
Won't that work?
Why should he remove everything and install everything again?
Won't be replying to PMs for a while. Stay in touch with e-mail.
Read before asking / messaging any moderator for any query: FAQ + answers for new members
ico is offline
Old 04-06-2009, 09:51 PM   #11 (permalink)
Everyone Has the common sense to Backup all data
Old 04-06-2009, 09:52 PM   #12 (permalink)
Anyways this isn't the FIGHT CLUB, So plz stop or you will get me banned for the usage of some bad lingo
Old 04-06-2009, 09:53 PM   #13 (permalink)
I'm Joking
Old 04-06-2009, 09:55 PM   #14 (permalink)
Please post everything in a single post. That makes the thread look neater. Thank you.
If you've missed something, then you can always your post.
ico is offline
Old 04-06-2009, 10:03 PM   #15 (permalink)
I do not get any Edit Button in my Posts.
A bug???
So i use this
Old 04-06-2009, 10:12 PM   #16 (permalink)
Check it yourself
Old 04-06-2009, 10:32 PM   #17 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Yup, that should work.
Won't that work?
I'm Joking
A bug???
So i use this
Check it yourself
That's 8 posts for... what? There is an EDIT button for everyone; you're no exception and it's not a bug. Posting an edited image will get you nowhere.
Stop posting just for the sake of it. Apparently the posts in this section do add to your total post count.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'.
www.abhi247.com | The Photohblog
Kl@w-24 is offline
Old 04-06-2009, 10:42 PM   #18 (permalink)
The Black Waltz
Crazykiller, don't you EVER learn?
Cool Joe is offline
Old 05-06-2009, 06:44 AM   #19 (permalink)
Also, AFAIK the EDIT button is also very well present at the bottom of every post which you post.
ico is offline
Old 05-06-2009, 08:45 AM   #20 (permalink)
Linux User
* Download this file http://1gighost.com/ed/ta/boot98c.exe
* Double click on it and it will ask for Floppy. Insert Floppy in Floppy Drive and click Ok.
This will create Windows 98 Bootable Floppy. Insert Floppy in a machine having problem.
* Set Floppy Drive as First Boot Device in BIOS. You can enter in BIOS by pressing F8, Del or Esc keys. A help message like "Press <xyz> key to Enter in BIOS" appear in most of machines at startup.
* Boot up machine and it will drop you at A:\> prompt.
* Execute fdisk /mbr command at A:\> prompt.
* Reboot Machine.
If you want to use SuperGRUB CD/USB/Floppy, download necessary files from its website and follow instructions from here.
Old 05-06-2009, 12:17 PM   #21 (permalink)
Why don't you come to my home and check it? I am not getting the Edit Button!
And you can remove those posts if you want.
Get a mod and make him merge all those posts.
And no one can edit those pictures so well that the Button simply vanishes.
Old 05-06-2009, 12:44 PM   #22 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
LOL, where the HECK IS THE "EDIT" button??????????
http://pleaseguide.me/
comp@ddict is offline
Old 05-06-2009, 03:47 PM   #23 (permalink)
Post Re: UNINSTALL LINUX (PLZ HELP)
thanks a lot mates even i had that problem but i solved it by reading this thread
.................u r so help ful.....i really mean it
thj1990 is offline
Old 07-06-2009, 12:06 PM   #24 (permalink)
Unhappy Re: UNINSTALL LINUX (PLZ HELP)
* Reboot Machine.
NOTHING SEEMS TO WORK
TELL ME HOW TO REMOVE EVERYTHING N START START FROM BEGENING . LIKE A NEW BROUGHT PC .
PLZZZZ HELP
Old 10-06-2009, 10:28 AM   #25 (permalink)
Linux User
Could you explain a bit more? Which method did you try? Any error message?
Old 09-07-2009, 05:05 PM   #26 (permalink)
I think you should try Stellar Phoenix Linux Recovery tool which works on windows and can solve your issue.give a try
Imogen Thomas is offline
Old 09-07-2009, 05:54 PM   #27 (permalink)
TheSaint
NucleusKore's Avatar
http://support.microsoft.com/kb/247804
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
