20-06-2005, 10:44 AM
win 98 not detecting cd rom drive. dos and xp detects it
hi i have intel 915 gav m.b and compaq cd drive the problem is that win 98 does not detect cd drive . win xp detects it without any problem . when i put a bootable cd in the cd drive and start computer then i get option to boot from hdd or from cd rom . this means dos is decting cd drive.but why isnt wi 98 decting cd drive
is it because of stata ?
so please help me and tell why my win 98 does not detecting cd drive?
20-06-2005, 01:54 PM
Just Do It
When I change the drive to CDrom in DOS/MSDos mode/Command Prompt it says Invalid Drive Specification... Now whats that .... But it reads the drive in Win98...
20-06-2005, 05:29 PM
Rebooting
i have tryed it with defrent mobo... UATA system... so will this work not not, i dont know... but u can try it.. try to go to divice manager the find the IDE ATA/ATAAI controler
delet/uninstall the Secondary IDE channel restart ur system & install the drivers again... get back here...
20-06-2005, 09:26 PM
well its some win 98 problem
i had it too.
i just reinstalled win 98(took14 mins)then it was all ok
by reinstalling i mean her just overwriting the files, nothing is lost, only windows files are overwritten.
but it is only possible if u have win98 cd or have it saved on ur hdd..
"Try again, fail again, fail better" - Samuel Beckett
20-06-2005, 10:47 PM
i reinstalled win 98 4 times still it did not work
help me
20-06-2005, 11:12 PM
You can try disconnecting the bus for cdrom . Then after that u can reconnect and check @ cmos whether its detected. Then try booting in win98 , perhaps this cud solve ur problem.
You can also try deleting the sec-ide as suggested by sauravcheeta.
There is no use in reinstalling windows for this problem.
Hibernating ....
21-06-2005, 07:27 AM
thanks man i tried all these still didnt work . dos is detecting it . that means cos also is.
when i start win 98 i et a error sayig the device attached to system in ini file is not valid. vnetbios is the file i think . does this have any thing to do with it?
i could not delete IDE ATA/ATAAI controler. and in device manager their is lot of conflicts shown
21-06-2005, 08:14 AM
reply
cannot find a device file that may be needed to run Windows or a Windows application. The windows registry or SYSTEM.INI file refers to this device, but the device file no longer exists.............
vnetbios.vxd
21-06-2005, 08:44 AM
Rebooting
in details pls...
21-06-2005, 08:49 AM
Rebooting
just uninstall this one....
21-06-2005, 12:00 PM
how do i upload image as saurav_cheeta has done
21-06-2005, 12:14 PM
when i remove it i et the error
" this device is a part of multi -functional device and cannot be rremoved in dependently to remove this device remove the mulitifunctional parent"
the parent has even primary channel
21-06-2005, 05:35 PM
If u have installed win98 in C drive
There should be two files in C directory.
1.Autoexec.bat
2.Config.sys
THey may be hidden so check them.IF they are not there create them.
Then edit these two files accordingly as suggested below:
In Autoexec.bat
C:\windows\command\Mscdex.exe /d:mscd001
(add this line in autoexec.bat file using notepad and save it)
In config.sys
device=C:\windows\command\ebd\oakcdrom.sys /d:mscd001
(add this line in config.sys file using notepad and save it)
Now restart
NOTE:If u have installed in other drive leas say D drive,then replace C with D in the above steps.
21-06-2005, 08:18 PM
Rebooting
to remove it u need to boot in or log in in safe mod.... hit F8 when u r booting in... then select boot in Safe mob...
21-06-2005, 08:22 PM
Rebooting
By the way Adi...
is ur CDROM in the secendory channel.... or it pluged in as a slave of primary master (That is ur HDD)???
this the most important question at this ponit.....
21-06-2005, 08:41 PM
thanks Mahesh Babu it worked
but how do i remove the hardware conflicte in device manager
21-06-2005, 08:58 PM
intel 's 915 gav m.b des not support win 98 so the graphics and sound r not working any idea to make them work
i think...the best solution to every windows problem lies in 5 sinple steps....
1:-backup ur valuable files in c: (asuming u have windows installed in c)
2:-boot in dos thru a bootable floppy or cd
3:-type format c:
4:reinstall windows
5:-enjoy.
this problem happened to me several times when i used to have windows 98.but after getting xp its gone.i used to follow these simple steps since my first compter....which was celeron 533 mhz with 64 mb of ram.man do u know how much i paid for that system---60000 rs.at that time it was a powerhouse.
21-06-2005, 11:09 PM
#19 (permalink)
3:-type format c:
4:reinstall windows
5:-enjoy.
Yes dude u are correct ,even i used to do the same thing whenever i get some problem in windows98 on my old celeron 400Mhz ,96Mb ram.
21-06-2005, 11:31 PM
#20 (permalink)
Rebooting
but have u guys saw... this adi dude have writen that i had formated & reinstalled his system many times....
21-06-2005, 11:44 PM
#21 (permalink)
I don't remember him saying that he has clean formatted the system.
What he said was he reinstalled the OS many times.
21-06-2005, 11:48 PM
#22 (permalink)
Re: reply
vnetbios.vxd
U need to install network neighbourhood again.Uninstalling network driver and reinstalling the drivers would do the trick.(During network driver installation it may ask u for Windows 98CD)
22-06-2005, 05:43 AM
#23 (permalink)
intel 's 915 gav m.b does not support win 98 se so the graphics and sound r not working any idea to make them work
where ca i get driver for win 98? cant find on intel's site
22-06-2005, 09:03 AM
#24 (permalink)
what is 3rd party drivers?
24-06-2005, 08:16 AM
#25 (permalink)
doesnt any kow what 3rd party drivers are?
