Old 19-06-2005, 11:55 AM   #1 (permalink)
Default Software for Hardware problems
I am using Windows XP Home EditionSP2. I heard that there is a freeware Software that enables to inform us about the Hardwares Problems.Your need your details
kumarn_2004 is offline
Old 19-06-2005, 10:24 PM   #2 (permalink)
maybe you can try sissoft sandra, everest etc... i dont think they will give you information on the Hardware problems. But they however will give you information on your Hardwares.
valtea is offline
Old 19-06-2005, 11:15 PM   #3 (permalink)
nikhil's Avatar
you got hardware problems...hmmm sounds serious..maybe well...you see guys have the hardware and the girls have the software..there might be a mismatch problem...needs some corrective action
nikhil is offline
Old 19-06-2005, 11:17 PM   #4 (permalink)
ya try out ....
sisoft sandra ..... www.sisoftware.demon.co.uk/sandra
get everest frm
www.snapfiles.com/get/everest.html
grinning_devil is offline
- by gohan89
