Old 12-05-2009, 06:49 PM   #1 (permalink)
Default system becomes unstable on right clicking
hello friends my os windows xp p4 recently my system hangs on right clicking a file.please offer me a solution
bkmishra1000 is offline
Old 12-05-2009, 06:57 PM   #2 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Default Re: system becomes unstable on right clicking
Did you install any software before this happened?
Also check if this helps!
http://windowsxp.mvps.org/slowrightclick.htm
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 12-05-2009, 07:51 PM   #3 (permalink)
paroh's Avatar
It is a shell problem download shexview and disable the shells in 50 combination or more and check each time whether it works for u or not. and if it works only disable the shell which is causing the problem and enable other shell
http://www.nirsoft.net/utils/shexview.zip
paroh is offline
Old 13-05-2009, 08:32 PM   #4 (permalink)
Thanks
my problem has been solved acting on the solutions offered in the forum thanks friends for the prompt response
bkm
- by gohan89
