Old 09-05-2009, 09:59 PM   #1 (permalink)
THE SIMPLE MAN
MR.MOUSTACHE's Avatar
Question Driver problem
hi guys my old system is running with an agp gfs 6600-8x 256mb card now today i reinstalled da os and i dont have the driver for my card i searched for it in the net but could not find the excat vopy .... the one i can find is of GeForce 6600 if i install that will it be compatiable ? .... if not can u guys suggest me something
People laugh Because Am Different. And I Laugh Because They Are All The Same......
MR.MOUSTACHE is offline
Old 09-05-2009, 10:09 PM   #2 (permalink)
Default Re: Driver problem
http://us.download.nvidia.com/Window...glish_whql.exe
ico is offline
Old 09-05-2009, 11:12 PM   #3 (permalink)
Expanding a bit on ico's reply: you don't need a driver specifically for your gfx card. NVidia has what are called "unified drivers" which are common to a wide range of gfx cards in the same series.
In fact, the driver provided by the manufacturer of your gfx card is just a copy of NVidia's unified driver. The driver provided for download from the NVidia website is always the latest version and will be much newer (and faster) than the one that came with the card.
If you want to find out for yourself, go to http://www.nvidia.com, then to the "Download drivers" page. You will be presented with the option to choose your GPU series (GeForce 6 series in your case) and your OS. This will lead you to the download page.
pimpom is offline
Old 10-05-2009, 06:40 PM   #4 (permalink)
THE SIMPLE MAN
so does that mean that i can install any of drive for my gfx card ?
Old 10-05-2009, 08:45 PM   #5 (permalink)
silentFOX
mittyr's Avatar
@MR.MOUSTACHE
Yes. Just make sure its for "GeForce 6-Series" as "pimpom" mentioned.
OR
If your not still sure of it, go to this page. Do the auto search option.
http://www.nvidia.com/Download/index.aspx?lang=en-us
mittyr is offline
Old 10-05-2009, 09:22 PM   #6 (permalink)
In simple words, there is only one driver setup for nVidia cards, of which I've provided the link.
ico is offline
Old 12-05-2009, 06:45 PM   #7 (permalink)
THE SIMPLE MAN
thanks guys its done and working well ~~~~ thanks to @ico and @ mittry
MOD CAN CLOSE DOWN THE TOPIC
Old 13-05-2009, 06:51 PM   #8 (permalink)
^ you should also thank pimpom for a very good explanation.
ico is offline
- by gohan89
