Old 09-05-2009, 02:48 PM   #1 (permalink)
Default Help Needed
Can Anyone Please Tell me the best FREE antispyware and anti malware available and also the links to download them????
xqub33 is offline
Old 09-05-2009, 02:55 PM   #2 (permalink)
Default Re: Help Needed
awww is offline
Old 09-05-2009, 04:41 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
check www.filehippo.com
There is a section for AV's, download the free one of ur choice.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 09-05-2009, 04:54 PM   #4 (permalink)
Thanks a lot comp@ddict
xqub33 is offline
Old 09-05-2009, 09:00 PM   #5 (permalink)
i have one more query
my computer had win xp installed. i installed win 7 on a dual boot.
after abt 1 month i used EASEUS partioion manager to delete the partions which contained win 7 and merged its space with other partions. now whenevr i boot i get the menu to choose btw xp and win 7 ,which is not present.how do i fix this???
thanks in advance.
xqub33 is offline
Old 09-05-2009, 09:08 PM   #6 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Cool Re: Help Needed
thanks in advance.
You can just edit the boot.ini file (present in windows drive) to remove the OS name.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 09-05-2009, 09:23 PM   #7 (permalink)
Call me D_J!
Disc_Junkie's Avatar
^Yup that's right!! Here are the steps:
1. Rightclick My Computer and select properties.
2. Select Advanced and click on Startup and Recovery
3. Click Edit(it will open boot.ini) and delete the line having Windows 7 in quotes. Save it and click on OK.
That's done!!
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 09-05-2009, 09:34 PM   #8 (permalink)
but it does not show any line containing win 7
here's what it shows:::
;Warning: Boot.ini is used on Windows XP and earlier operating systems.
;Warning: Use BCDEDIT.exe to modify Windows Vista boot options.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT
xqub33 is offline
Old 09-05-2009, 10:22 PM   #9 (permalink)
Call me D_J!
That's strange!! ^Which one is by default highlighted?? If it's WinXP then try by changing the value of timeout from 30 to 0. It will not show the menu as the time for displaying it is changed to 0 seconds!!
Or take a loot at this: http://www.tech-recipes.com/rx/1040/..._boot_machine/
And this
http://www.ditii.com/2009/01/28/how-...7-boot-loader/
Old 10-05-2009, 01:33 PM   #10 (permalink)
well thanks for helping but the thing is that in boot menu win 7 is selected by default so setting the timeout to 0 would probably make the win 7 boot........also i don't have my win xp cd
so the link is not much helpful
i think this is happening bcoz i deleted the partion instead of formatting it......
any comments??
xqub33 is offline
Old 10-05-2009, 03:14 PM   #11 (permalink)
Call me D_J!
^^Before deleting you should have modified the boot.ini file as is given in the second link.
Check this: http://www.techspot.com/vb/topic88921.html
Also check this: http://windows7forums.com/windows-7-...-ini-file.html
Otherwise clean install is the best....
- by gohan89
