Hi everybody,,,
I have problem related to Folder View Setting.....
My 'Desktop' Folders and ' My Document ' folders are Always open as a thumbnail view .....
Its annoying.....
First Let me tell you All...
--->> Some week ago i was not able to see hidden folders...and folder options for Hidden files had some problem...
So i had Reset View for All folders...And my folders view settings had been changed..
Then i found it was because of the Recycler Virus..jwgkvsq.vmx worm
You might know this...
i have removed it..
but my folder view settings have lost...
I know the BagMRU Size registry ...i make it 5000...
and i have checked also " Remember each folder view setting " in folder option
But can not solve the Problem..!
Now....Only " Desktop " and " My Document " Folder's view remains in Thumbnail ..
And i cant change view for them..
While Disk's folders are in normal view as i set them.
Only Folders on Desktop ,, My document and including Recycle Bin..have thumbnail view always...
Please somebody change them..
(((Please pardon my English)))
