Re: Help Please....unwanted folders and files showin up in Ext.HD??????
If these files are genuine data files that need to be deleted, and refuse to go away, then you have to run scandisk from command line as follows:
CHKDSK [drive:] /F /V
How to use this? Plug in your external hard disk. See the drive letter in My Computer. For example, if it is E then
CHKDSK E: /F /V
Note
To open a command prompt, Start->Run
command
press ENTER
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
Reason: Missed the [b]:[/b]
