Old 02-05-2009, 09:12 PM   #1 (permalink)
Default Urgent mobile net help!!!
Hi guys,plz help on dis1,i recently putd net on my mob n da prob is net works fine on opera but da 'connectin' screen gets stuck in instant messg eg ebudy,morange,nimbz etc. Wats da prob? Plz help!
pranavrahul is offline
Old 04-05-2009, 08:31 PM   #2 (permalink)
thinking di9it'al
di9it's Avatar
Exclamation Re: Urgent mobile net help!!!
what's the model/make of your mobile?
Different apps use different configuration settings. Check whether you hav activated common settings for all the apps in ur mobile.
My Rig:
AMD Athlon 5600+ @ 2.9GHz
Gigabyte M61PME-S2 MainBoard
Kingston 1x2GB 800MHz DDRII RAM
GFX Card : ???
HTC Touch Pro
di9it is offline
Old 09-05-2009, 02:11 PM   #3 (permalink)
Default Re: Urgent mobile net help!!!
What's your carrier?
ico is offline
- by gohan89
