Old 27-04-2009, 08:11 PM   #1 (permalink)
Question Locked my drives with Folder Lock! Please help....In great trouble
Hi All,
I've locked my E: drive and some folders in C: drive using folder lock software. Now the Folder lock's UI is not appearing and instead a white window appears with no bottons(I'm using windows Vista Home Premium).I'm unable to access my E: drive and those locked folders of C: drive. Even if i go to cmd and try to access E:, it's saying E: is not accesible. I'm in great trouble guys. Please help me out and tell me if there is any way i can recover my data from E: and C: drives.
Regards
Sunil
sunilkb25 is offline
Old 27-04-2009, 08:25 PM   #2 (permalink)
Free Like a Cloud
Default Re: Locked my drives with Folder Lock! Please help....In great trouble
if u still have restore point just restore it
Yasa_Zidfrau is offline
Old 27-04-2009, 09:23 PM   #3 (permalink)
U can restore it or if doesn't works then try to uninstall the software ...'
If then it not works then format the c drive and remember one thing never store any important data in c drive or in the os drive...'
Arnab boss is offline
Old 27-04-2009, 09:35 PM   #4 (permalink)
On KillingSpree!!!
scavanger007's Avatar
did u try reinstalling folder lock?
if not, then try it, so that the missing files will be placed and mayb ur gui will b back...
if not then bad luck
btw i m using folder lock since 4 years and never faced this problem, probably u downloaded from torrent which 90% times creates problems
No matter how much time u spent climbing up, u may still fall in an instant. -Max Payne 2
scavanger007 is offline
Old 28-04-2009, 09:51 AM   #5 (permalink)
No guys. I tried reinstalling it, but the installation is failing. Even it is not getting uninstalled, and giving error as the drives and folders are locked. Can any of u please suggest if i can go to cmd and unlock my locked folders. As i have specified before, I'm unable to go to my E: drive from cmd (I have locked the whole E: drive).
Old 28-04-2009, 12:53 PM   #6 (permalink)
On KillingSpree!!!
format c and then u will have ur e drive back to normal....(at the stake of c: though)
Old 28-04-2009, 10:56 PM   #7 (permalink)
Use any file recovery software to recover the data . I remeber when Norton or some other AV had delete folder lock dll's and i couldnt open folder lock . I used Get back data software to recover the files. ..
hope this works for u too.
agm_1052001 is offline
Old 29-04-2009, 02:31 PM   #8 (permalink)
tHe rEacTioN iS hEaTinG
tejass's Avatar
Wink Re: Locked my drives with Folder Lock! Please help....In great trouble
Originally Posted by sunilkb25 View Post
Hi All,
Regards
Sunil
try startin in SafeMode..can be of great help!!
f33ls gUd 2 c0me bACk 2 pAviLLioN
tejass is offline
Old 30-04-2009, 11:42 AM   #9 (permalink)
Thumbs up Re: Locked my drives with Folder Lock! Please help....In great trouble
Hi All,
Thanks a lot to all of you guys, for suggesting so many ways. A big thanks to the digit software troubleshooting forum also.
Day before yesterday i was able to unlock all my drives and folders from the evil folder lock, by opening in safe mode. The folder lock UI appeared, and I was able to unlock all the locked items.
Regards
Sunil
Old 01-05-2009, 01:24 PM   #10 (permalink)
prateek007391's Avatar
Nope this is wrong
Y r u blaming Folder Lock
It was completly ur mistake
check the article misuse of technology
prateek007391 is offline
Old 01-05-2009, 10:35 PM   #11 (permalink)
Fresh Stock Since 2005
Hi All,
Regards
Sunil
please post some details of the software you are referring to. A link to it will be useful.
http://www.khattam.info
khattam_ is offline
Old 01-05-2009, 11:16 PM   #12 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
^He already found the answer...
THREAD CLOSED...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
