Old 26-04-2009, 07:23 PM   #1 (permalink)
Default DR watson post mortem debugger
hello friends i came across this dialog box tiltled -
Dr Watson Post mortem debugger has encountered a problem and need to close, sorry for the incovinence. i want to know wht is this and is it a virus or malware, and
2nd problem -
after my pc boots one small dialog box appears stating - setting personalised setting for RECYCLER.exe/s/ something like that, IS THAT ALSO A VIRUS.
KINDLY ADVISE,
I USE AVAST ANTIVIRUS PROFESSIONAL
tHANKS
Necessity is the mother of Invention
NiluGeek is offline
Old 26-04-2009, 07:39 PM   #2 (permalink)
lost in my world
yippee's Avatar
Default Re: DR watson post mortem debugger
Dr watson is a windows program
http://support.microsoft.com/kb/308538
i dont know about recycler.exe i will post if i come up with something useful.....
yippee is offline
Old 29-04-2009, 08:22 AM   #3 (permalink)
Call me D_J!
Disc_Junkie's Avatar
2nd problem -
KINDLY ADVISE,
tHANKS
Yes it is a malware. You can try to block the program from getting executed by using Zone Alarm. I used to get it and I did the same.
And for Recycler.exe, yes it is a malware. Delete it using Noob Killer or block that too using Zone Alarm.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 29-04-2009, 07:49 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
i was too facing it....and it was not allowing me to be online more than 5min....use zone alarm and block it
VarDOS is offline
