Hi.. thanks for your reply..
I have searched for the particular file (
C:\Windows\system32\MSCFGTLC.XML) all over in my system, there is no such a file in Vista.
As you said, I'm using this software only for folder security since it is a wonderful one. I can even try any alternative. Can you please provide me info about any best alternatives? I dont want to encrypt folders, I just want to hide, lock, & protect folders. Drag and drop facility should also be there..
As u suggested, Folder Lock is an option, but I think hiding option is not available there.
Please suggest me such a software.. thanks dear..
