Old 23-04-2009, 09:42 PM   #1 (permalink)
powering up
Mohnishgs's Avatar
Unhappy installations taking tooooooooooo long..... please help
no matter what i try to install it takes way too long...... once i click on install, it starts immediately but is stuck at 0% for a long time(20-30mins) then it proceeds at normal speed..... but thats not the case with all the installations
it happens for all the installations which use install shield wizard(and some other installations too) and also for installations of windows updates(though it never proceeds beyond 0% for win update)
Asus P5KPL-CM
Intel C2D e7300 @ 2.66ghz
4gb Transcend ram
Palit HD4830 512mb gfx card
Western digital 500gb hdd
Dell 17" lcd monitor
Mohnishgs is offline
Old 26-04-2009, 11:04 AM   #2 (permalink)
D@rekills4's Avatar
Try getting latest Windows Installer
After installing see if the installing gets faster
If not then I think you need to reinstall your OS
D@rekills4 is offline
Old 24-05-2009, 01:06 PM   #3 (permalink)
Blogger
hariharakumar's Avatar
Default Re: installations taking tooooooooooo long..... please help
i think there is a problem with install shield wizard, as D@rekills4 said try getting latest Windows Installer, which will be found in Microsoft website.
Visit my blog at http://geekspage.tk/
Check my blog for updates on Blogging, Social Media, Software.
follow me on Twitter: http://www.twitter.com/hariharakumar
hariharakumar is offline
