Old 23-04-2009, 04:25 PM   #1 (permalink)
THE SIMPLE MAN
MR.MOUSTACHE's Avatar
Question Audio Driver Problems
I'd like to think myself a relatively computer literate person, but I can't figure this out at all! First of all, my computer is running Windows XP Performance SP 3 (performance version), so I think it may have to do with missing windows components. Whenever I try to install my audio driver (I have the soundcard that uses the Realtek High Definition Audio driver) it asks for .DLLs, .SYSs, and .DRVs, so I located and download the files, used those, and it seems like the install goes smoothly other than that. Then after restarting my computer, I have no sound, so I go and check my audio driver in the sounds and audio devices section in control panel, and it says under device status: Windows cannot load the device driver for this hardware. The driver may be corrupt or missing. (code 39). Troubleshooting button just says that I need to reinstall. Any else having this problem and fixed it?
i have even tired installing the latest version of the drivers update ..it does not work
People laugh Because Am Different. And I Laugh Because They Are All The Same......
MR.MOUSTACHE is offline
Old 25-04-2009, 08:55 AM   #2 (permalink)
Amir.php's Avatar
Default Re: Audio Driver Problems
You need a patch from microsoft:
"kb888111xpsp2".
open your driver cd and search this patch in Audio folder.
Extract it in folder with winrar.
Now goto device manager> and right click on unknown Device and choose update driver.
Browse to the path of your exracted folder and click ok.
Now patch will install.
Now you can install your sound driver without any problem.
http://amirphp.wordpress.com
Amir.php is offline
Old 25-04-2009, 05:18 PM   #3 (permalink)
THE SIMPLE MAN
"kb888111xpsp2".
thanks man .... i will try to look into it if not corrected will contact u for more help !
Old 26-04-2009, 07:55 PM   #4 (permalink)
THE SIMPLE MAN
Exclamation Re: Audio Driver Problems
"kb888111xpsp2".
No dice. Did as you said and restarted my computer, same thing as before it also asked for the .DLLs as before.
Old 26-04-2009, 08:33 PM   #5 (permalink)
Amir.php's Avatar
Dont no why you are facing this problem.
But the method i suggested is for those who have High Definition Audio & unable to install Driver on Splitreem Win Xp sp3.
Due to need of this patch.
Amir.php is offline
