Old 21-04-2009, 02:52 PM   #1 (permalink)
mccm's Avatar
Default Cannot open my Hard Disk!! Help!!
Hi,
I Cannot open my hard disk its shows me this error!
And when i right click and try the 'Open' features it shows this error msg again.
And again when i try install and and scan my pc with anti virus is delete all the .exe files which are not even virus and important file. Please help me..!!!
mccm is offline
Old 21-04-2009, 04:13 PM   #2 (permalink)
Default Re: Cannot open my Hard Disk!! Help!!
your antivirus has probably deleted important system files. try to repair os.
Posted again:
anupvirkud is offline
Old 21-04-2009, 04:24 PM   #3 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
i can't see ur pics bro
upload on tinypic and post
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 21-04-2009, 05:22 PM   #4 (permalink)
mccm's Avatar
Well, thanks for the reply. but all i can say is that i heve tried installing and repairin a new os but doesn't work. and i also try scanning them using AVG with latest updates 18.04.09. but this doesn't help too.
mccm is offline
Old 21-04-2009, 08:52 PM   #5 (permalink)
Call me D_J!
Disc_Junkie's Avatar
Install Noob Killer and do a 8-X kill. It will clear out the malware.
www.freewarefiles.com/Noob-Killer_program_42299.html
And if you have already deleted it, then download Virus Effect Remover and remove the effects of virus.
www.softpedia.com/get/Security/Secure-cleaning/Virus-Effect-Remover.shtml
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 21-04-2009, 08:58 PM   #6 (permalink)
Overlord v2.0
alexanderthegreat's Avatar
Try this:-
1> Right click on that F drive and click on Properties.
2> Click on the Security tab.
3> Click Advanced.
4> Select the concerned account click on edit. Select “This folder, subfolders, and files” click ok.
5> Place a check next to the text “Replace all existing inheritable permissions on all descendants with inheritable permissions from this object."
This should reset the permissions. See if this works...
Also, run a chkdsk scan.
The Only quote worth quoting: "E Loboa!!! What man???
Forum Rules:http://www.thinkdigit.com/forum/announcement.php?f=16&a=1
Disclaimer:No offence meant to ANYONE!
alexanderthegreat is offline
Old 22-04-2009, 06:30 AM   #7 (permalink)
Bill Gates's Avatar
There is a utility in windows called the 'system File Checker' that checks if the necessary system files are intact in the system.... for using it, Insert ur windows XP SP3/SP2 cd.... then Start>Run>type in cmd .... when the command prompt opens up type in sfc/scannow and press enter.
this will open the system file checker ...it will compare the system files in ur comp with that on the CD... if any mistakes are found, the concerned system file is replaced with that on the cd...
Also beware that any custom themes applied by altering system files may be disabled since this returns ur windows installation to the default form.... njoy..!
Linux sux...
Bill Gates is offline
Old 22-04-2009, 10:50 AM   #8 (permalink)
You can download autorun eater software for this problem. I m also face this problem and solve by this software.
deepakkanyal is offline
Old 22-04-2009, 07:44 PM   #9 (permalink)
Fresh Stock Since 2005
can you access your drive by typing f:\ in your address bar??
http://www.khattam.info
khattam_ is offline
Old 20-05-2009, 02:51 PM   #10 (permalink)
mccm's Avatar
Oh! Thanks to all for replying. Got many work so i just formatted all my drives and install a new one. And sorry you guys for letting you know a little late. Thanks
mccm is offline
Old 20-05-2009, 03:07 PM   #11 (permalink)
mccm's Avatar
Thanks and Long live Digit
mccm is offline
Old 20-05-2009, 05:06 PM   #12 (permalink)
paroh's Avatar
To protect yourself in future install USB disk security.
paroh is offline
