Re: Dual Boot Problem..plzzzzzz help
No problemo. When your computer boots up it will look for the master boot record in the first hd. If it is doesn't find any, it will look for it in the second hd. If it still doesn't find it then something definitely went wrong somewhere.
Just remember to connect both drives if you decide to install your OS's separately on each drive. But it is better if you install both OS's on a single drive.
Lag in my favourite MMO :-(
