Old 12-04-2009, 04:20 PM   #1 (permalink)
Default help!! pdf properties to word properties
hello friends,
i want to print my PDF files in WORD format.
but the problem is that i can't set-up desired MARGIN in WORD.
so how can i change pdf properties of file to word properties in my desired way.
hoping for all yr cooperation.
raj_kshetri is offline
Old 12-04-2009, 06:25 PM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: help!! pdf properties to word properties
* Try converting online: http://www.zamzar.com/
* Also check out: http://www.google.co.in/search?q=onl...&safe=off&sa=2
- MrinTech :)
mrintech is offline
Old 13-04-2009, 04:38 PM   #3 (permalink)
thanks 4 yr suggestion.
but i need some offline working software.
so can u suggest me other?
Old 13-04-2009, 06:29 PM   #4 (permalink)
Wise Old Mouse
mrintech's Avatar
This is really good software: http://www.hellopdf.com/download.php - I have personally tried it
But after some conversions it asks you to solve Maths Problem to carry on further free conversions. Try it
- MrinTech :)
mrintech is offline
Old 16-04-2009, 03:31 PM   #5 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
There are many out there, adobe acrobat also lets you to do that...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 27-04-2009, 05:58 PM   #6 (permalink)
ya thanks to all.
but i think i can't explain my problem well.
1>the problem of "hellopdf" is that after u get the key online,u can't use it offline.i have tried it.
2>acrobat converts pdf to word for sure ya,but i can't change the properties of pdf file to be fully compatible in word.
So FRENS,is there some other way?
Old 27-04-2009, 06:44 PM   #7 (permalink)
Democracy is a myth
rhitwick's Avatar
There is a software "PDF to Office". It converts PDFs to PPT and Word.
BUT, its not free.
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
