i am not able to boot into the normal mode.i had formatted my hard drive and had done a clean installation.still i am not able to boot in normal mode.i am able to boot in safe mode
my system details:-
mother board Intel D102GGC2
processor intel R pentium D CPU 2.80Mhz
system bus speed 800Mhz
system memory speed 533 Mhz
L2 cache Ram 1024 kb
os win xp sp2
it all started with a Jammer virus problem.inspite of number of virus scan ,the problem remained.
then i had first formatted the c drive and installed os.since i was able to boot only in safe mode,i formatted hard disk and reinstalled win xp sp2.still same problem.
before formatting initially,i had done a Ram upgradation from 512 mb (2 256 ddr2 rams) to a single Ram of 2 gb. thinking it as a ram problem,i had tried to boot in to normal mode with my old ram also.still same problem.
i am having a bios problem also.
i am able to change the boot sequence in bios,however,i am not able make the change/save permanently.even after removing and replacing cms batterythe situation is same.
i had tried, sfc in safe mode-windows file protection could not initiate a scan of protected files
the specific error code is ox 000006bc {the rpc server is unavailable}
Ms config: in start up item only rundll32 srclient
when pressig f8 the boot sequences are
safe mode
safe mode with networking
safe mode with command prompt
last known good configuration
start windows normally
usual option of vga mode is missing.
i am in total mess.can somebody help in resolving the ssue?
