Re: blocking contents of a dvd
Password protected ISO is a similar but simpler method than passworded rar, cuz you can mount iso files using daemon tools/magiciso whatever.
but no, its impossible to make them access the data but not copy it. depending on the data, you can try but any protection can easily be bypassed.
