Old 09-04-2009, 12:12 AM   #1 (permalink)
Default help ...dual boot vista and xp
hello everyone ...
i was using xp and vista on my pc .....(xp wainstalled previously on c drive and then i installed vista on d drive) ..everything was working fine ...i used to get the option to choose from xp or vista on system startup....but yesterday xp was giving some trouble and was dead slow ..therefore i reinstalled xp on c drive ...now the problem is that i have stopped getting the option from xp or vista at startup....xp automatically boots .....please help me enabling the dual boot again ....thanks in advance
maverick5678 is offline
Old 10-04-2009, 12:19 AM   #2 (permalink)
aswin1's Avatar
Default Re: help ...dual boot vista and xp
Download Vista Boot Pro [Google for it] and install in XP. Correct boot option through it.
aswin1 is online now
Old 10-04-2009, 01:09 AM   #3 (permalink)
Gowt1ham
Gowt1ham's Avatar
DOwnload a boot manager like^ and u can boot into vista or Xp. Ur XP partition is marked active so ur are booting directlt into Xp.
PII 965 BE @ 4ghz|CM 10 |8GB GSKILL Ripjaws|Aerocool V12|MSI 790gx g70|EVGA GTX 260 OC |CM UCP 900W| CM Stacker 830 nvidia Edition+13 fans| BenQ 24"| Logitech G15 & MX 518| 2TB HDD|AD700+E7/E9
Gowt1ham is offline
Old 11-04-2009, 08:23 PM   #4 (permalink)
if vista is already installed
visit the following link for step-by-step guide
http://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed _first__the_stepbystep_guide.htm
greenmile is offline
