Old 06-04-2009, 09:38 PM   #1 (permalink)
powering up
Mohnishgs's Avatar
Unhappy serious internet issues..... PLEASE HELP!!!
1. The max download speed i can get in torrents is 5kbps...
i tried port forwarding but it doesn't work
i even tried the software pfconfig to forward ports, but still the problem persists......
iam using hauwei smartAX MT882 modem and the connection type is PPPoE(bsnl 500 plan)
(i have already referred to the previous threads regarding this but nothing's working)
2. In the past couple of days youtube and megavideo have slowed down like hell(though my speed test results show that my dl speed is 1460kbps i only get around 48kbps) but the downloads done through downthemall and internet download manager are still fast
3. The direct downloads through rapidshare though initially is fast(60KBps) reduces drastically after about 100MB of download(10KBps)
iam using windows vista
PLEASE HELP!!!
Asus P5KPL-CM
Intel C2D e7300 @ 2.66ghz
4gb Transcend ram
Palit HD4830 512mb gfx card
Western digital 500gb hdd
Dell 17" lcd monitor
Mohnishgs is offline
Old 06-04-2009, 10:10 PM   #2 (permalink)
Searching...
Default Re: serious internet issues..... PLEASE HELP!!!
Check for your firewall and antivirus settings. May be something is intereferring! Also check if any application is using internet for updates etc and hence sharing bandwidth. (Check windows update)
Run a spyware scan too! Hope that helps
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
Old 06-04-2009, 11:39 PM   #3 (permalink)
powering up
Mohnishgs's Avatar
i have already checked all that
Asus P5KPL-CM
4gb Transcend ram
