| Forum |
#1 (permalink) |
i am facing a strange problem in my window xp sp3 c2d 2.66 n 4 gb ram problem is that i have organized my collection of pics n video in different folder like i used to store movie with their subtitle in seperate folder under the head of one folder called MOVIES now when i am clicking on the folder called movie to open it opens but when i am opening a folder which contain only movie file my system hangs and then have to cancel the operation via task bar result in restart of explorer...i can play the movie via built in browser of media player but cant via directly in other word if i am opening any folder which contain only movie then my system hangs i am using vlc player n KIS 2009 fullly updated ....have already scanned my system plz tell me what to do |
#2 (permalink) | |
Call me D_J!
If it hangs when you open a folder, then I think those movies are in thumbnails and are in large number for which a lot of memory is needed to display them together simultaneously and a lot of processing power is required. Check by unticking the Thumbnails view in the View bar. It can also take place due to messing up of FFDShow. Uninstall the player with the codecs and try. It may work fine. KLite is a good media player. Use that!!
ASUS K42JA-VX032D RAWKS !!!!!! Last edited by Disc_Junkie; 05-04-2009 at 03:20 PM. |
#3 (permalink) |
sorry for that line
i mean i have one folder called "movie" which contain sub folder containing different movies and my systems hangs when i am opening a folder which contain only movie file not a single file of different type then my system hangs like D:---MOVIE(no problem)--->folder(raaz 2)-->system hangs |
#5 (permalink) | ||
but problem is not solving... |
#6 (permalink) |
Call me D_J!
Then the problem is likely to be with ffdshow. Uninstall the codecs and the player and check!!
----------------------------------------- Posted again: ----------------------------------------- And also install them again
ASUS K42JA-VX032D RAWKS !!!!!! Last edited by Disc_Junkie; 05-04-2009 at 03:38 PM. Reason: Automerged Doublepost |
#8 (permalink) |
Hmm , are you able to browse the folder via media player ? (files-open then browse) or just you are playing the video with shortcut link ? Are you sure that you are able to play movie in media player that is in the hanging folder ?
Go to run , type cmd , if your movies directory is in x drive then type x: and enter . Type chkdsk . Try this , might be the folder got corrupted. Where x may be c,d,e etc, ur drive letter
Off From Digit Forum for some months.....busy |
#9 (permalink) |
Call me D_J!
ffdshow is a image filter whcih comes installed when you install a codec package such as vlc. Some error may have crept in. Uninstall vlc and reinstall and it would solve the problem.
ASUS K42JA-VX032D RAWKS !!!!!! |
#10 (permalink) | |||||
i have already did that but no result Quote:
ya i am be able to browse the folder via media player i am playing video from its location via browsing ya i am able to play every file via browsing instead of going direct to the location of the file my system hangs very next moment when i am opening the folder containing the video file even i am not be able to click on the file n now i just noticed that i am not be able to acess my one partition coz in the root of that partition there is a video file ----------------------------------------- Posted again: ----------------------------------------- Quote:
Last edited by ashishstillthere; 05-04-2009 at 08:30 PM. Reason: Automerged Doublepost |
#11 (permalink) |
That seems a problem with the explorer.exe
Can you please post the hijackthis report here , i might help then . Also try to repair your xp instal lation using the cd . Waiting for hijackthis report .
#12 (permalink) | |
here is the log file
#13 (permalink) |
Banned to Spam
Location: Look below...not under pants dumbo...use a GPS
You have no virses running...this may be due to corrupted Explorer.exe, try running "sfc /scannow" to check if there are any problems...
My DeviantART page now exists !!! Krazy-Bluez.deviantart.com Twitter: http://twitter.com/KrazyBluez |
#14 (permalink) |
Start | Run REGSVR32 /u SHMEDIA.DLL
this will deregister Windows Media DLL wich assecces File info for details/thumbnails etc Test your issue/problem WiTHOUT rebooting - then if it goes away - Reboot and try again - post results in order to ReRegister, in case no luck; REGSVR32 /i SHMEDIA.DLL |
#15 (permalink) | |
thanks paroh...my problem is solved...can you plz elaborate what actually has happened to my system in simple n in detail form |
#16 (permalink) |
here regserver is the program for managing dll (dynamic link library) files , that you can say act like plugins for windows for extra information or managing some particular process . If you had installed some program which showed info for the media files , it had registered with the media dll to show info for the files . but due to some reasons (got corrupted) it was unable to show info and your system hanged . /u stands for unregister , thats what shmedia.dll got unregistered and came to the default by windows , you can say your media info plugin got unistalled (or dll got resetted) And you are happy now
| Bookmarks |
| Thread Tools | |
| Display Modes | |
