Old 05-04-2009, 09:29 AM   #1 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Default Vista Issues, Again...
I've been using Vista for quite a while now... but its been acting up as of late.
  1. It randomly stalls. In the sense pauses, becomes unresponsive, and then continues after a few seconds as if nothing happened.
  2. If I open up some folders, they take over thirty seconds to display the contents, even if there are only a few files in them.
  3. The mouse doesn't get stuck during these stalls.
  4. During these stalls, the cursor changes into the loading one [the green whirly thing]
  5. The frequency of the stalls is variable. Sometimes, it stalls five times in a minute, or not even once in an hour,
  6. The above are COMPLETELY random. An event that causes it to stall once need not stall it if recreated.
On my part, there is nothing I have really installed newly or anything. It just seems to have started off on its own!
Any help would be greatly appreciated, as I can't seem to put my finger on the problem.
Config :
  • E6550
  • MSI P6N SLi V2
  • 2*1GB 667 MHz DDR2 [Transcend]
  • 160 GB SATA [Seagate]
  • XFX 8600GT 256 MB
  • All components are at stock speeds and voltages
  • Vista Ultimate, patched with latest hotfixes.
Homer: God bless those pagans.
ring_wraith is offline
Old 06-04-2009, 12:52 AM   #2 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Default Re: Vista Issues, Again...
If you think there isn't any virus then re-install vista
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 08-04-2009, 08:17 PM   #3 (permalink)
=--=l33t=--=
No viruses.. checked with two scanners.. NOD32 and AVG...
Reinstall? How is that going to help? The problem just cropped up all of a sudden! I don't want to reinstall Vista for no reason.. I mean it is kind of a tedious process....
Old 08-04-2009, 08:23 PM   #4 (permalink)
check the rams and HDD cables if they are seated properly
oc is fail is offline
Old 09-04-2009, 08:36 AM   #5 (permalink)
=--=l33t=--=
Checked... all connections are secure..
anything else?
Old 09-04-2009, 08:42 AM   #6 (permalink)
Searching...
Run a good anti-spyware (though I don't think this might help, but still give it a try ).
Also check if any files are corrupted using the Vista repair mode!
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
Old 09-04-2009, 09:36 AM   #7 (permalink)
Run a Linux Live CD/DVD to work in Linux mode... Use if for a while... If similar problem occurs, you are more likely dealing with hardware issues and not software issues... On the other hand, if you have no problem with it, may be you have some issues on your Vista installation or some malware problems... Try working in safe mode for a while also...
Arun
sakumar79 is offline
Old 10-04-2009, 12:03 AM   #8 (permalink)
aswin1's Avatar
I had a similar problem while using Avast antivirus with Vista. May be due to some incompatible programs. Try uninstalling any programs recently installed.
aswin1 is offline
Old 10-04-2009, 04:02 PM   #9 (permalink)
=--=l33t=--=
I'm starting to think its a Hard Disk issue... because my RAM checked out clean [ran MemTest for over 8 hours]... what else can it be?
I really don't think its something to do with Vista, coz I actually had Ubuntu on dual boot, and when I tried logging on to that to see if the problem extended into Ubuntu, then it just ran a disk scan and started throwing up errors... I rebooted into Vista and ran SeaTools, the diagnostic utility to scan my disks and its not detecting my HDD!!!
I actually ran diagnostics before with SeaTools, so what's up now?! Any alternative tools to check for HDD issues?
But what's bugging me is that the OS has no reason to constantly access the HDD right? I mean when I'm.. say.. surfing the web, then its all running from the RAM right? Why should the HDD be accessed at all? Is it? I'm not too sure.
Also, I noticed that the problem increases when I perform tasks that are HDD intensive.. like playing a video or even a song!
Old 10-04-2009, 04:21 PM   #10 (permalink)
=--=l33t=--=
Update : okay, now I'm nearly sure that its a HDD issue. I managed to log onto Ubuntu and the problem isn't nearly as bad as Vista, but its there. When I try to access my HDD from Ubuntu, the file browser crashes. The same stalling thing also happens, but rarely.
Are there any tools apart from SeaTools I can use? And how is it that my HDD is not showing up in SeaTools? Is it like.. fake or something? Is that even possible?
Old 12-04-2009, 05:48 PM   #11 (permalink)
=--=l33t=--=
Anybody?
Old 18-04-2009, 12:32 AM   #12 (permalink)
aswin1's Avatar
Download Hirens BootCD and burn it on a CD. Boot through this CD. It has many HDD checking software.
aswin1 is offline
Old 18-04-2009, 12:43 AM   #13 (permalink)
The Frozen Nova
casanova's Avatar
I trust whenever you are noticing these stalls, you would be hearing a clicking noise from your harddisk.You hear these noises whenever there are bad sectors. Check your hard disk for bad sectors.
www.nerdweed.blogspot.com
casanova is offline
