Old 04-04-2009, 02:45 PM   #1 (permalink)
Tich tor ang tesmur
Default Bypass Folder Lock
I a using this software Folder Lock 5.9.5
now i had locked this folder sometime back using this software and now i have forgotten the password i had used!!
..can anyone help me bypass/crack the password and open the folder.
boom2709 is offline
Old 04-04-2009, 02:48 PM   #2 (permalink)
PSN~ftw
NoasArcAngel's Avatar
Default Re: Bypass Folder Lock
try using unlocker ... google it ... try and see if that works ...... or what type of file is it ??? ?? is it encoded like .rar or .zip ???? then it may be a little difficult to crack the password out!
Best of luck !
NoasArcAngel is offline
Old 04-04-2009, 03:02 PM   #3 (permalink)
expertno.1's Avatar
^^lol unlocker is a process killer not a decrypter .
If the folder had been encrypted then their is no way out other than to know the password .
expertno.1 is offline
Old 04-04-2009, 04:01 PM   #4 (permalink)
expertno.1's Avatar
^^why are you spamming all the way around ??
@topic:
better to contact the software company and see if they can help you .
Old 04-04-2009, 06:28 PM   #5 (permalink)
geek........
Gauravs90's Avatar
Folder lock application just add an extension in the folder.
If you want to retrive the information just boot in with another OS like linux or bartpe then go to desired folder and remove the extension you can also try DOS in safe mode to do that.
Gauravs90 is offline
