| Forum |
#1 (permalink) |
PSN~ftw
note : i even tried to install the c compiler [gcc . rpm packacges ] but i haven't suceeded as yet ...! !! please help me out guys as i am a die hard fan of die hard and wanan apply the matthew farrell theme!!!!!!!!!!!!!!!!!!!! Thanks : frustrated Windows Xp user |
#2 (permalink) |
Who stole my Alpaca!
The reason you are likely getting this error is because you dont have certain packages installed required for compiling . Could you post the error message you get? Also check opensuse forums and irc and you should be ok. Personally I think you should be installing from its repositories rather than compiling stuff.
The Ultimate Chess Strategy : "Hit Hard, Hit Fast and Hit Often" |
#3 (permalink) | |
PSN~ftw
| Bookmarks |
| Thread Tools | |
| Display Modes | |
