Old 01-04-2009, 10:57 AM   #1 (permalink)
Welcomes u all...
aQi_g's Avatar
Default modem drivers problem
Hi,
My PC specs are
WINXP SP 2
160 GB HDD,
1 GB ram,
amd athlon 5000, 2.61 Ghz,
512 kbps Internet connection,
security softwares installed:
avast home edition AV,
spybot S & D,
autorun virus remover 2.3.
the issue now is when i try to install my modem drivers from the BSN: provided cd
the installation goes unsuccessful ,a msg box comes up saying ''A service installation section in this INF is invalid"
the modem model is UT 300 R2u.
plz help
A journey of a thousand sites begins with a single click!
The geek shall inherit the earth!
aQi_g is offline
Old 01-04-2009, 11:05 AM   #2 (permalink)
Wise Old Mouse
mrintech's Avatar
Default Re: modem drivers problem
Browse through: http://www.google.com/search?hl=en&s...id&btnG=Search
- MrinTech: http://mrintech.com/
mrintech is offline
