| Forum |
#1 (permalink) |
Thanking you Hidayath |
#2 (permalink) |
Call me D_J!
Is it BSOD? If it is so then boot up in safe-mode and uninstall the the drivers. Restart normally and reinstall the new ones from their website. It will work.
ASUS K42JA-VX032D RAWKS !!!!!! |
#3 (permalink) |
Tech Addict
^^^ Ok agreed !!
@OP : There should be a Error Description with STOP Codes [Given in hexes] , Note the Details along with the stop codes. This will help us in further Analysis of the issue. Although in apparent situation it seems to be a result of a Recent Software update issue [In your case its the GFX Drivers]. So do note the Stop Codes if if occurs again.
|► My Blog : http://extremetecharena.blogspot.com ◄█► Software News Thread : http://tinyurl.com/SoftwareNT ◄| |
#6 (permalink) | |
Tech Addict
For this . Start -> Right Click on "My Computer" -> Properties -> Advanced -> Under "Startup and Recovery" click "Settings" -> Find "Automatic Restart" and Uncheck it. -> OK -> OK. Then Whenever the BSOD Occurs then Just Note Down the Stop Error Code given in Hexes and Post the Stop Code Here for us to help analyse it better.
#7 (permalink) |
Banned to Spam
Location: Look below...not under pants dumbo...use a GPS
^ If it's not possible to boot in xp then ???
For this try to bring up the boot options menu by pressing F8 and selecting "Disable Automatic Restart on system failure" and press enter twice.... @OP: If it's IRQL Error, then try removing any new hardware that you've just installed...
My DeviantART page now exists !!! Krazy-Bluez.deviantart.com Twitter: http://twitter.com/KrazyBluez |
#9 (permalink) | ||
----------------------------------------- Posted again: ----------------------------------------- Quote:
----------------------------------------- Posted again: ----------------------------------------- stop:0x0000008e(0x0000005,0x80522b8e,0xba50dad0,0x 00000000) Hello this is the error am getting this error messages plz help me out of this problem. My MB is Biostar Last edited by hidayath7; 04-04-2009 at 10:49 AM. Reason: Automerged Doublepost |
#10 (permalink) | |
#11 (permalink) | |
Banned to Spam
| Bookmarks |
| Thread Tools | |
| Display Modes | |
