Old 11-06-2005, 06:24 PM   #1 (permalink)
Default how to create a WinXP bootable CD
I want to know how to create a WinXP bootable CD in Windows XP.
Also just tell me if it is possible to create a WinXP bootable cd in Win98.
thanx in advance
harshagarwal is offline
Old 11-06-2005, 06:28 PM   #2 (permalink)
u must have all windows XP setup files, then use n-lite to create a WinXP bootable cd.http://nuhi.msfn.org
Shwetanshu Srivastava
shwetanshu is offline
Old 11-06-2005, 09:14 PM   #3 (permalink)
l33t n00b!
Nimda's Avatar
I recommend creating an XP bootable CD which has Service Pack 2 integrated into it. That way, you save time by installing SP2 alongwith XP. To create such a "slipstreamed" CD, visit:
http://www.winsupersite.com/showcase...slipstream.asp
Here's another guide from a different site:
http://www.uniquehardware.ca/guides/...5/guide5.1.php
Nimda is offline
Old 11-06-2005, 11:28 PM   #4 (permalink)
aadipa's Avatar
Have a look in our very own tutorial section
http://www.thinkdigit.com/forum/viewtopic.php?t=18785
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 12-06-2005, 03:51 AM   #5 (permalink)
Harsha U are asking the same questions which are repeated may a times. do a Search and u get tons of replies.
RajŪ Anyone else is not me...!!!
rajas is offline
Old 12-06-2005, 04:54 AM   #6 (permalink)
Fresh Stock Since 2005
Yeah a search here in thinkdigit or google will answer all your questions........
You should search once before you ask for a solution...........
http://www.khattam.info
khattam_ is offline
Old 12-06-2005, 08:08 AM   #7 (permalink)
hey it was already published in digit november'04 page 80
I\'m the game & want to play
salils is offline
Old 12-06-2005, 01:29 PM   #8 (permalink)
sachin_kothari's Avatar
Dont Integrate SP2 into the bootable XP CD. I did it and my system crashed a several times. My hardware was not properly detected. It created a lot of problems forcing me to satisfy myself with XP SP1.
Progress is not made by Hard Workers! But by LAZY people.
Coz they try to find Easier Ways of doing the same thing.
sachin_kothari is offline
Old 13-06-2005, 11:12 AM   #9 (permalink)
to create a live xp cd, use bart's pe builder
google for it !!!
cyberia.in is offline
Old 13-06-2005, 11:21 AM   #10 (permalink)
l33t n00b!
Nimda's Avatar
You're the first guy who's saying this. I and all my friends have experienced better performance because from what I've seen, installing from an SP2 slipstreamed CD doesn't seem to slow down the system as opposed to the usual slowdown caused if you install XP and then install SP2 separately.
Regarding stability, that is most probably not due to the slipstreamed version. Install XP alone, and then SP2 and tell us if it is still unstable.
Nimda is offline
