Old 26-03-2009, 07:33 PM   #1 (permalink)
Unhappy problem with folder lock 6.1.2
Hi before I srat sorry for bad english
I used folder lock 6.1.2 to lock some files few months ago.
I reinstalled my OS and the damn folder lock and now when I try to open the files it tells me wrong password maybe I forgot it how can I open that locker without a password
thanks in advance
tmn50 is offline
Old 27-03-2009, 12:13 AM   #2 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Default Re: problem with folder lock 6.1.2
Just use the Serial key as password...it would work then...but only if you've enabled the "Master Password" option....which is BTW applied by default...so it should work...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 27-03-2009, 01:58 AM   #3 (permalink)
already tried not working
tmn50 is offline
Old 27-03-2009, 04:15 AM   #4 (permalink)
Gowt1ham
Gowt1ham's Avatar
I presume u have lost ur password.
This is not the most efficient way but it works nonetheless
Install an OS in another partiton and access(linux or XP)
Gowt1ham is offline
Old 27-03-2009, 04:18 AM   #5 (permalink)
the problem came when I installed my new os windows trust v3
when I put the right password the blue screen came
tmn50 is offline
Old 27-03-2009, 11:34 AM   #6 (permalink)
Call me D_J!
Disc_Junkie's Avatar
There is no way to open the folder if you loose the password.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 27-03-2009, 11:44 AM   #7 (permalink)
Gowt1ham
Gowt1ham's Avatar
No dude, I meant u access the file/folder from an OS that is installed in a different pen Drive/Hard disk/ or partition.
My sister accessed all the folders I had locked thru openSuse. So unless it is encrypted u can access it from any other OS.
Gowt1ham is offline
Old 27-03-2009, 02:39 PM   #8 (permalink)
Banned to Spam
Boot from a live linux cd...like ubuntu and copy all the data to your pen drive...
Old 27-03-2009, 08:42 PM   #9 (permalink)
guys this software encrypt and lock folder and save them as .flk file that contain everything that you wanted to secure the problem is when I put the correct password my computer get stacked and the darn blue screen came if you have any information about this problem tell me
btw Gowt1ham what was so important so your sis have done all that to see it I encrypted and lock the folders for the same raison damn for sis
tmn50 is offline
