Old 25-03-2009, 10:59 AM   #1 (permalink)
static_x's Avatar
Smile Video DVD creation Problem
I was trying to make a Video DVD of some rock videos. I used nero Vision for it...evrything went just fine and the dvd was done in 1.5 hours after all the reencoding of the video formats...now wehn i play the dvd on my dvd player the first menu comes up with 12 thumbnails on the first page and when i select the first one it starts playing but after finishing the 12th song it again goes back to the 1st one....I mean if i dont press the next button after the 12th song then it goes back to the 1st one...i think there is some problem in understanding the ROOT MENU & MAIN MENU options....just wondering if anyone could be of some help in this regard..
static_x is offline
Old 26-03-2009, 09:53 PM   #2 (permalink)
silentFOX
mittyr's Avatar
Default Re: Video DVD creation Problem
@static_x
You haven't mentioned how many videos are actually there (Am gonna assume it as more than 12 videos) ?? And "Nero" version ??
Are the "Videos" under one "Titleset" ??
You may try checking the settings under "Menu Creation". After selecting the basic layout, at bottom of the same window "click" on "More" option.
If you have multiple titlesets, under "When finished playing a title" choose which option you want
- Jump to the next title
- Repeat the title
- Jump back to the Main/Title Menu
This should solve your problem.
To add, ConvertXtoDVD is a better option...user-friendly & encoding quality.
mittyr is offline
Old 30-03-2009, 11:38 AM   #3 (permalink)
static_x's Avatar
Originally Posted by mittyr View Post
@static_x
Thanks a lot mate..i'll definitely try it out...i hope things will work now...
static_x is offline
