Old 11-06-2005, 09:52 AM   #1 (permalink)
Default another damn problem...caused by windowblinds...
HI people...recently i installed windowblinds and hell lotta skins for it...then after some time when i used to apply a skin style..only the colors wud change ...the taskbars,etc wud remain the same(windows classic)...so i decided to remove it...and now after uninstalling it from the add/remove programs...it is still there in the start menu and the windowblinds window stil opens!!!...and when i goto control panel>display>appearance>under the windows and buttons tab..the skins sill exist!!...pl tell me how to completely remove windowblinds from my system.
I have windows xp pro with service pack 1.
thankyou
hearthacker is offline
Old 11-06-2005, 10:02 AM   #2 (permalink)
l33t n00b!
Nimda's Avatar
Did you revert to the default theme first, and did you then unload WindowBlinds? It is very important that you unload WindowBlinds first since files that are running can't be deleted. If you have StardockCentral installed, uninstall through there.
Also visit:
http://www.stardock.com/products/windowblinds/faq.html (search for "uninstall" in this page).
Nimda is offline
