Old 22-03-2009, 08:55 PM   #1 (permalink)
We Need Freedom Again
x69x's Avatar
Lightbulb BSNL Broadband Help - Ask your Question here
Today i m in very good mood , i saw some threads regarding bsnl connectivity ,
if you have any just ask here i will reply , just have lots of experience with bsnl since 2005 . no i dont work for bsnl , just was a trainee in graduation for like one month
i have 750 plus plan and getting full 2mbps speed around 217 KB/sec , yup its not a
joke
on mumbai server
on lahore server
they just have one server in india to test on
=========some problems and answers =========wait for more==or just ask ===
I m clearing some terms for simple home user , so its not for books ,exams, technical users etc
==========What is bridge ==========
1.BSNL recommends bridge connection , which simply means they want you to use your router as a bridge ,between your pc and BSNL Server
BSNL server ( exchange ) --------- --------Router----------------your pc
>>What is PPPoE ?
BSNL server are ppp type server , which simply means that they require a username and password to access the network
>>Why they Don’t configure router and why they make connection in pc ?????
Hmm the answer is bit tricky , most of bsnl employees are not well educated ( yes this is The truth ) ,they simply don’t have the knowledge of original routing networks etc etc , so BSNL teach some simple steps to employees ,so they can just make bsnl work for homes .
i dont mean to heart bsnl employees or their sons or daughters , but its kinda truth ( Personal Experience )
They escape to configure the router use it as a bridge and make connection in your pc . one more truth is router settings are also very difficult for most of home users.
But once they configured they don’t have to change again n again. No matter which operating system you use , then you just have to plug LAN wire into your pc which may be laptop etc , OS reinstallation doesn’t affect router settings . router just need to be DHCP enabled
>>Why we see limited connectivity icon ??
#From the point of view of OS (XP )
Yes there was connectivity bug in older versions , just update your xp to SP3
#From the point of view of router ,
Router is not enabled for DHCP , open your router cpanel ,which is commonly 192.168.1.1 or 192.168.1.2
And enable DHCP
>> I can't Acces my router cause of limited connectivity ???
Its simple
1.Go To network connections (don’t ask me where it is )
2.Right click on ”Local Area Connection” and click on “properties” at bottom
3.in General Tab scroll some down , and select “ Internet Protocol (Tcp/IP) “
4.Click on “Properties “ below the upper box
5.Select the option “ use the following ip address “
And fill
Ip address : 192.168.1.2
Subnet mask : 255.255.255.0
Default gateway : 192.168.1.1
Leave the DNS servers blank
7. click okay
8.click okay of properties box.
I hope now your limited connectivity icon is gone and you can access your cpanel at
192.168.1.1
Just enable dhcp in that
Most common username/ password are
admin /admin
admin/password
>>why BSNL disconnects me when I try to download something for long time ?
Just for load balancing , they configured their servers for this , yes this is painful for me also
Kind Regards
X69X
×÷·.·´¯`·)» ÑØ FRÊÊ £Úñ¢H «(·´¯`·.·÷×
x69x is offline
Old 22-03-2009, 09:24 PM   #2 (permalink)
IM ThE DEVIL
Davidboon's Avatar
Default Re: BSNL Broadband Help - Ask your Question here
are u serious or just joking around here ??
i cant believe that !!
AMD Phenom II X6 1055T||MSI 890FXA-GD70||CORSAIR 4GB DDR3||2 * SEAGATE 500GB + WD 500GB ||ASUS EA5870 1GB||RAZER ARCTOSA||RAZER DEATHADDER||NZXT M59||BENQ G2220HD||CORSAIR TX650W||Canon 550D
Davidboon is offline
Old 22-03-2009, 09:29 PM   #3 (permalink)
Rockstar11's Avatar
Zindagi Toofani Hai... Jahan Hai DuckBurg!
Rockstar11 is online now
Old 22-03-2009, 09:36 PM   #4 (permalink)
x69x's Avatar
i can download 250 mb in just one n half hour lol , a full film (liltle bit compresed )
x69x is offline
Old 22-03-2009, 09:41 PM   #5 (permalink)
Call me D_J!
Disc_Junkie's Avatar
He is in such a good mood today that he don't mind posting unbelievable things. Jame raho bhai Jame raho.
ASUS K42JA-VX032D RAWKS !!!!!!:grin:
Disc_Junkie is offline
Old 22-03-2009, 09:46 PM   #6 (permalink)
Section Moderator
gopi_vbboy's Avatar
remember u dont get 200KB/S in 750Plan...may be u may get 200kbps(bits/sec)
gopi_vbboy is offline
Old 22-03-2009, 09:46 PM   #7 (permalink)
x69x's Avatar
guys i know your pain of 256 kbps ( 25 to 35 KB/Sec ) , but believe me mine is 217 KB in real but they just disconnect me more like just after 100 to 200 seconds on full load
n my connection redials in 1 sec and get on line again
x69x is offline
Old 22-03-2009, 09:58 PM   #8 (permalink)
i dont exist's Avatar
Originally Posted by x69x View Post
sometime there is problem in usernames and passwords on the bsnl server which authorize your connection
Is there a way to get around the authentication server?
i dont exist is offline
Old 22-03-2009, 10:02 PM   #9 (permalink)
x69x's Avatar
Originally Posted by i dont exist View Post
Is there is a way to get around the authentication server?
Ya may be its INDIA lol , but all usernames and passwords are locked by phone numbers in most of exchanges ( i think all now ) you can't use other username/password
using of others accounts was possible 2-3 years back
x69x is offline
Old 22-03-2009, 10:07 PM   #10 (permalink)
Thanks
Posted again:
i used home 500 plan last year and when i login to check my usage sometimes i get redirected to someone else's account and i was able to see their name,usage,and all other personal details and why is that?
Last edited by i dont exist; 22-03-2009 at 10:10 PM. Reason: Automerged Doublepost
Old 22-03-2009, 10:17 PM   #11 (permalink)
x69x's Avatar
hmm thats serious problem , may be there was problem in creating account of same username ( broadband account )
or website scripting error , server lag , something like that
Manymore things are possible with BSNL , dont worry you just faced one lol
x69x is offline
Old 22-03-2009, 10:24 PM   #12 (permalink)
well it happened more than once and i had account number,phone number and names of atleast of five people all over the india their name is not even identical to mine the only problem i had is that i dont have their password guess what could happen if someone could use these accounts
Old 22-03-2009, 11:14 PM   #13 (permalink)
x69x's Avatar
mate its easy to guess password ,cuz bsnl employees make that , but there is doubt in using another account , cuz here in punjab is locked by phone numbers
mean u cant dial another username password from your phone , simply you cant use another persons account
when i was trainee in bsnl that thing is possible and people start complaining about it , so they solved this issue and locked all connections
now new connections are already configured for this ,
dont know ,if it still working in other parts of india
very easy to guess username and password ,cuz they set "password" as password for each new connection lol
x69x is offline
Old 22-03-2009, 11:18 PM   #14 (permalink)
lol
Old 22-03-2009, 11:19 PM   #15 (permalink)
The official BSNL thread:** Post all your BSNL Dataone Related Queries Here **
ico is offline
Old 23-03-2009, 05:30 AM   #16 (permalink)
I use a home 500c plan with 256kbps and the BSNL people said they would upgrade me to 2mbps soon It happened as yet THEN WHEN WILL IT....Its About 1 yersince they promised me that ...S
sireesh is offline
