Old 19-03-2009, 10:34 AM   #1 (permalink)
Default Please help!
Hello all, I have a PC running Windows XP Service pack 2 with a 80GB HDD. My Windows folder is installed on the Drive C: partition which comprises of 19.5GB.
Now the problem is when I right click my Windows folder and select properties, it shows that the size is 9.21 GB! Is this normal for a Windows XP folder because I asked my other friends and they all replied "about 4GB". I even ran a full system scan using an updated Kaspersky 2009 and it detected no viruses. Checkdisk hasn't shown any errors as well.
On the other hand, the weird part happens when I go inside the Windows folder. I selected all files using CTRL+A and then checked the size, it says 4.5GB! How come outside the folder it says a different fact? Please help me!
saiyaman is offline
Old 19-03-2009, 11:08 AM   #2 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: Please help!
I'm trying to answer ur question. This is my assumption.
First The windows folde contains numerous hidden system files. Unhide them and the try Ctrl+A and Prop.
Then, there comes PageFile. It would take twice ur RAM, and if Hibernation enabled then that also would take twice ur RAM. Then, if u've enabled System Restore, it would take some place (a very much amount)
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 19-03-2009, 01:44 PM   #3 (permalink)
silentFOX
mittyr's Avatar
Default Re: Please help!
Try "WinDirStat"
It will show you the details of all the files in any drive. My guess is its old "windows updates" (Read as "crap") thats taking up some of that space.
Try "Tuneup Utilities". It does a good/safe job in getting rid of all crap.
mittyr is offline
Old 19-03-2009, 07:12 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Run DiskMax, CCleaner and TuneUp Utilities.
dheeraj_kumar is offline
